Re: Mag/distrubutor removal and reinstall
Posted by Nat 2 on January 08, 2007 at 07:21:57 from (64.80.108.52):
In Reply to: Mag/distrubutor removal and reinstall posted by G Campbell on January 08, 2007 at 07:04:33:
There should be a single notch on the crankshaft pulley, and a pointer on the front cover of the engine. That's TDC on #1 cylinder, but that could be TDC on the exhaust stroke or TDC on the compression stroke. IIRC, it's the single notch. There may also be a double notch, which is for checking advance with the engine running. Hopefully someone will correct me if I'm wrong. The easiest way to find TDC is to remove #1 spark plug, put your thumb over the spark plug hole, and slowly rotate the engine until air starts whistling out around your thumb. Align the mark, and you're at TDC. HOWEVER, if you marked everything, made sure nothing fell apart, and didn't rotate the engine while you had the mag off, you should be able to put it right back on, and the tractor will start and run just like it did before.
Home
| Forums
Today's Featured Article -
Diagnosing Engine Difficulty - Diesel Tractors - by Staff. The following suggestions are listed for your assistance. You can make simple adjustments on your tractor that will improve its operation and save you the time and expense of hiring someone to do it for you. Always make one adjustment at a time, and if the adjustment made does not improve the condition, return to the original setting before proceeding to the next adjustment. Hard Starting Cold air temperatures. Insufficient fuel.
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2024 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
