Re: Checking Voltage of a generator
Posted by John T on January 10, 2007 at 07:42:26 from (66.244.90.5):
In Reply to: Re: Checking Voltage of a generator posted by Roger Mills on January 10, 2007 at 06:03:24:
Thanks Roger, Ive learned something today yayyyyyyyyyyyyy My generic Troubleshooting Procedure was written with John Deere tractors in mind that use EITHER the 2 pole (BAT GEN) Cutout Relay and the Light Switch (works same on all brands and as you described, low charge via resistor or high charge dead grounded via the light switch) ORRRRRRRRR the 3 or 4 terminal Voltage Regulator and I knew many IHC were the same. HOWEVERRRRRRRRR I was well aware of some of the IHC Cutout Relays also having the FLD terminal but thought??? they still werent full fledged Voltage Regulators but Cutout Relays or modified cutout relays ONLY.... BUTTTTT I WAS NOT aware when n where n how they wired actually and was gonna ask Bob M someday. I didnt realize when they were used one didnt use the light switch then ?????? I guess I still dont know if they are alwayssssss in the low charge resistive ground position or how n if they change to the dead ground high charge???? I reckon they could do so sort of like a regular VR i.e. switch from dead ground high charge to resistive ground low charge depending on voltage n current sensed which would make a relay open or close???????? (verus the manual settings on a light switch) HERES MY BEST GUESS of how they, work can you or Bob or Bob M settle this?????????? I guess they work kind of like a VR in that they sense the voltage n current of the genny versus the battery n switch from dead field ground for high charge but resistive ground for low charge buttttttttttt they arent as fancy n precise as a full fledged VR that uses kinda like pulse width modulation n relay chatter/switching to finer n better regulate the charge rate i.e. they have 2 stages ONLY Low or High charge unlike a VR that fine tunes the charge rate by relay chatter and pulse width type regulation Talk to me, that how those Cutout Relays work that have the FLD terminal on them????????????????????????????????????????????????????????????????????????? A Curious John T
Home
| Forums
Today's Featured Article -
Diagnosing Engine Difficulty - Diesel Tractors - by Staff. The following suggestions are listed for your assistance. You can make simple adjustments on your tractor that will improve its operation and save you the time and expense of hiring someone to do it for you. Always make one adjustment at a time, and if the adjustment made does not improve the condition, return to the original setting before proceeding to the next adjustment. Hard Starting Cold air temperatures. Insufficient fuel.
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2024 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
