Re: Farmall C questions
Posted by Janicholson on January 14, 2007 at 19:14:01 from (66.188.149.191):
In Reply to: Farmall C questions posted by BGunzy on January 14, 2007 at 18:49:44:
The bushing can be replaced by a machine shop. Lowes, or a good hardware store, may have one. If the shaft is worn, the bushing can be installed so it runs back into the cast drive housing about 1/2" giving new life to the dist. The play should be between .0005 and .0008. if it is as much as .002 it will have too much cam angle variation (it does now) Governor components are still available to some degree, I have no experience in them other than bushings. JimN
Today's Featured Article - Diagnosing Engine Difficulty - Diesel Tractors - by Staff. The following suggestions are listed for your assistance. You can make simple adjustments on your tractor that will improve its operation and save you the time and expense of hiring someone to do it for you. Always make one adjustment at a time, and if the adjustment made does not improve the condition, return to the original setting before proceeding to the next adjustment. Hard Starting Cold air temperatures. Insufficient fuel. ... [Read Article]
Latest Ad: Sell 1958 Hi-Altitude Massey Fergerson tractor, original condition. three point hitch pto engine, Runs well, photos available upon request [More Ads]
