Re: 300u Hydraulic worries...
Posted by Ted in NE on January 30, 2007 at 13:36:17 from (65.39.111.98):
In Reply to: 300u Hydraulic worries... posted by JayWalt on January 30, 2007 at 11:03:31:
The valves are factory from your description. You probably haven't changed anything, they can be set for single or double action. On the cover in the lever end is a round shaft with flats cut on it. Also has a roll pin through it into a clip. Cap has S & D stamped in it. Roll pin must be over letter or valve spool will not be centered & keep system on pressure when not useing valve. The larger block with the 4 bolts holding the cover on is the system relief valve. This valve has a orfice screen in it that can be plugged & cause the same problem. Need to remove the cover, screen is removed with a screw driver. Clean up also replace o ring on the unloading piston while have cover off. The cover has spring tension under it. Remove two bolts at opposite corners of cover & install longer ones to ease cover off & when installing also. The check block on the under side of the hitch valve would likely not cause the problem you describe. Ted
Home
| Forums
Today's Featured Article -
Diagnosing Engine Difficulty - Diesel Tractors - by Staff. The following suggestions are listed for your assistance. You can make simple adjustments on your tractor that will improve its operation and save you the time and expense of hiring someone to do it for you. Always make one adjustment at a time, and if the adjustment made does not improve the condition, return to the original setting before proceeding to the next adjustment. Hard Starting Cold air temperatures. Insufficient fuel.
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2024 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
