Reasembling Clutch-Torque Specs- WD6
Posted by Tyler Cohrs on February 12, 2007 at 20:06:00 from (198.70.5.111):
I'm putting the Clutch components together on my 1950 WD6 and would like to know the Torque Specs for everything. Mainly the Flywheel, Preasure Plate, and the four bolts on the clutch coupling shaft. Thanks for your help!!
Today's Featured Article - Diagnosing Engine Difficulty - Diesel Tractors - by Staff. The following suggestions are listed for your assistance. You can make simple adjustments on your tractor that will improve its operation and save you the time and expense of hiring someone to do it for you. Always make one adjustment at a time, and if the adjustment made does not improve the condition, return to the original setting before proceeding to the next adjustment. Hard Starting Cold air temperatures. Insufficient fuel. ... [Read Article]
Latest Ad: Sell 1958 Hi-Altitude Massey Fergerson tractor, original condition. three point hitch pto engine, Runs well, photos available upon request [More Ads]
