Re: valve lash/timing
Posted by ScottyHOMEy on July 17, 2007 at 18:07:15 from (70.105.246.111):
In Reply to: valve lash/timing posted by MARK DOUD on July 17, 2007 at 16:59:05:
Not sure where you got those numbers from, Mark. Intake and exhaust valve both shold be at .14, with the engine hot. The mark on the engine will be notoriously hard to find. A SuperC was the first tractor I rebuilt and I couldn't find the mark on the flywheel before the rebuild. When I had her all apart, I found it -- a line on the flywheel, but not stamped very deeply, and hiding in the surface rust. While I had it off and put a new ring gear on, I masked it off and painted (horrors) a JD yellow stripe over it. Get your engine to where #1 is at TDC, and look for the mark through the handhole in the bottom. Trust me, it's there. It should line up with the nub that's on the back of the flywheel cover. At that point you'll be true on TDC, and can commence to setting your valve clearances. Since there isn't a mark on the front of the engine for timing, you might find it useful (I have) to clean up a spot on the timing cover and the crank pulley once you get it to TDC. Take a piece of duct tape and draw a line on it with a marker. Stick the tape on the timing cover and the pulley so that the line bridges the gap, then cut it with a sharp knife. This will give you a reference point for TDC without having to crawl back under the tractor sixteen times. Works for setting valves, timing magnetos and all sort of other useful things.
Home
| Forums
Today's Featured Article -
Diagnosing Engine Difficulty - Diesel Tractors - by Staff. The following suggestions are listed for your assistance. You can make simple adjustments on your tractor that will improve its operation and save you the time and expense of hiring someone to do it for you. Always make one adjustment at a time, and if the adjustment made does not improve the condition, return to the original setting before proceeding to the next adjustment. Hard Starting Cold air temperatures. Insufficient fuel.
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2024 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
