Re: Farmall 300 missing but not under load
Posted by jonnny2006 on August 01, 2007 at 12:18:42 from (67.142.130.44):
In Reply to: Farmall 300 missing but not under load posted by Matt Compton on July 31, 2007 at 17:52:29:
I have a farmall h that does the same thing....I belive it is a weak spring(s) operating the valve. bottom line if a valve isent opening when it is supposed to it will miss. when under load there is diffrent pressure being applied to everthing. when things get sloppy they dont run like there supposed to. like for instince, going down a hill will make it miss worse or even back fire! well thats because there could be slop in the dist shaft. My M will miss when going down a big hill. I also had a 3 cylinder gas engine that ran crappy. i was going down a big hill and i put it in a lower gear and let the clutch out and it ran better after that, probally had a stuck valve or somthing that runs the valve. you can also break things this way too. oyu cant always see what it making them run bad. i look at it this way....i'm getting older and i don't run like i did 20 years ago. if you wanna make her run like new you will need to break down the engine and look for worn parts or damaged parts. My dad had a H that ran crappy we rebuilt her and she ran good til the same part went out inside of the engine bending push rods. Somtimes the cheep comes out expensive. the more you are around somthing the more you will understand it. i would never reuse a sleeve as that was the main problume with my dads H. he had his brother rebuild it and could not get out the no. 2 sleeve so they left it in and reused it. well that was the weak point.
Home
| Forums
Today's Featured Article -
Diagnosing Engine Difficulty - Diesel Tractors - by Staff. The following suggestions are listed for your assistance. You can make simple adjustments on your tractor that will improve its operation and save you the time and expense of hiring someone to do it for you. Always make one adjustment at a time, and if the adjustment made does not improve the condition, return to the original setting before proceeding to the next adjustment. Hard Starting Cold air temperatures. Insufficient fuel.
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2024 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
