Are You Cranking More and Enjoying it Less?
Posted by A. Bohemian on August 07, 2007 at 09:23:06 from (207.170.88.228):
In Reply to: Re: weak magneto posted by El Toro on August 07, 2007 at 05:22:40:
Quote: ''If you pull it over a cylinder at a time, it won't start. If you start spinning it over it will catch after a bit.'' Yeah. Catch your arm or your head, maybe. dlp, the SAFEST way to crank a tractor is to pull upwards, sharply, with the thumb NOT wraped around the handle. Spinning a tractor engine with the crank is NOT recommended. Until you fix your problem, pull this tractor if you must start it and you just might avoid a painful accident. True ''kickback'' (where the charge is ignited BEFORE top dead center while cranking, causing the engine to run backwards, thus locking the pawl and turning the crank into a lethal death machine) is less common in Farmalls than in Model T Fords, but it still happens. When it does, it can kill. To address your post directly: test the ignition system by making one of Dell's patented ''calibrated'' spark testers. Get a known good plug and bend the electrode out to 3/16.'' Ground it well and connect one of the spark wires to it. It should show a nice, fat blue spark. If the spark is narrow or off-color, that could account for your difficult starting. If so you can experiment with the choke. You shouldn't need the choke at all in warm weather, but sometimes choking a recalcitrant tractor with a weak ignition can make it easier to start. It also makes it very easy to flood the carb, so be cautious... You can also try the following, if you're not doing it already: BEFORE turning the ignition, pull on the crank six or eight times. THEN throw the ignition. This was the Farmall-recommended procedure. You sound very certain your timing is correct and your impulse is working properly, but I have read on these boards several times of the exact symptoms you describe being caused by a sticking impulse. Giving the crank some warm-up pulls can help alleviate this symptom.
Home
| Forums
Today's Featured Article -
Diagnosing Engine Difficulty - Diesel Tractors - by Staff. The following suggestions are listed for your assistance. You can make simple adjustments on your tractor that will improve its operation and save you the time and expense of hiring someone to do it for you. Always make one adjustment at a time, and if the adjustment made does not improve the condition, return to the original setting before proceeding to the next adjustment. Hard Starting Cold air temperatures. Insufficient fuel.
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2024 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
