Re: Instrument panel IH 886
Posted by K.B.-826 on August 09, 2007 at 22:32:38 from (68.115.104.106):
In Reply to: Instrument panel IH 886 posted by little man on August 09, 2007 at 21:48:23:
Looks like it's a 1981 model, last year they were built. The light with the round circle and the arrow, thats the air filter restriction indicator. Could be anything from a dirty filter to a bad sender or grounded out wire. Check the filter first. If the filter is OK, disconnect the wiring at the sender, which is located on the tube between the filter canister and the manifold, if the light goes out, sender is bad. If the light stays on, the wire from the sender to the light is grounded out. The light that comes on when you depress the clutch pedal is the trans lube pressure indicator. It is normal for it to come on when the pedal is depressed, and you may notice it blink when the TA is shifted.
Today's Featured Article - Diagnosing Engine Difficulty - Diesel Tractors - by Staff. The following suggestions are listed for your assistance. You can make simple adjustments on your tractor that will improve its operation and save you the time and expense of hiring someone to do it for you. Always make one adjustment at a time, and if the adjustment made does not improve the condition, return to the original setting before proceeding to the next adjustment. Hard Starting Cold air temperatures. Insufficient fuel. ... [Read Article]
Latest Ad: Sell 1958 Hi-Altitude Massey Fergerson tractor, original condition. three point hitch pto engine, Runs well, photos available upon request [More Ads]
