Need to get this engine running,and I am stuck!!
Posted by chadd on August 11, 2007 at 10:51:59 from (4.188.131.108):
I am still working on the C-153 engine for our combine. It only seems to run on two or three cylinders, lacks power, and just plain runs rouqh. The firing ends of the spark plugs from cylinders 1 and 2 are still white with some light brown and and the ends of the plugs on cylinders 3 and 4 are still covered with dark black, dry soot. If I switch the plugs around, they will change color within 20 seconds of running. I turned the motor over with a plug grounded against the block on each wire and each cylinder seems to have spark. I also tried to determine which cylinder(s) are the culprit by shorting out each of the plugs (one at a time). It seemed to run worse regardless of which one I shorted out, although it was hard to tell. I thought maybe the manifold passages were plugged, but that doesn"t seem to be the case either, as all of the exhaust and intake passages are clear in the head and manifold (I used compressed air, light, and a piece of wire to triple check). I did not see any missing pieces of the manifold gaskets or cracks in the manifold, so it seems unlikely that the intake is the culprit either. Does anyone have any other ideas? Thanks.
Home
| Forums
Today's Featured Article -
Diagnosing Engine Difficulty - Diesel Tractors - by Staff. The following suggestions are listed for your assistance. You can make simple adjustments on your tractor that will improve its operation and save you the time and expense of hiring someone to do it for you. Always make one adjustment at a time, and if the adjustment made does not improve the condition, return to the original setting before proceeding to the next adjustment. Hard Starting Cold air temperatures. Insufficient fuel.
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2024 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
