Posted by keith stromberg on September 01, 2007 at 13:50:22 from (74.244.168.169):
I have a 1968 140 Farmall with a push button starter switch. Replaced the switch several times in the last year (3 times) with a heavy switch that looks like the old dimmer switchs that mount in the floor of a car. Yeasterday went to crank it and the switch did not work again. Each one in the past have burnt the contacts. Am I doing something wrong? I would think that they should last a lot longer than they have. I have it wired breaking the positive battery cable then to the starter. The ignition wiring is on a key switch. I have considered maybe putting a solenoid on it to see if things last a little longer. Thanks for any help, and advise!
Today's Featured Article - Diagnosing Engine Difficulty - Diesel Tractors - by Staff. The following suggestions are listed for your assistance. You can make simple adjustments on your tractor that will improve its operation and save you the time and expense of hiring someone to do it for you. Always make one adjustment at a time, and if the adjustment made does not improve the condition, return to the original setting before proceeding to the next adjustment. Hard Starting Cold air temperatures. Insufficient fuel.
... [Read Article]
Latest Ad:
[More Ads]
