Re: shaft bearing
Posted by Chris NW Ind on September 03, 2007 at 10:47:14 from (64.136.26.226):
In Reply to: shaft bearing posted by farm it all on September 03, 2007 at 01:50:53:
Bearing is a light press fit on the output shaft and just fits inside the input shaft. I knocked it off with a hammer and punch and used the bolt and cap to pull it back on the shaft. As far as I can tell, the rollers will not fall out unless the bearing is damaged so I see no reason for a rubber band.
Do you have it completely apart yet?
Are you replacing the input shaft ball bearings and seals also? Since you have it apart as far as you do, I'd do that also. For myself, in addition to the above, I replaced the countershaft seal and belly pump seal and the 4th/5th slider. All the seals were leaking, but no more. Pretty easy job actually.
Chris B.
Today's Featured Article - Diagnosing Engine Difficulty - Diesel Tractors - by Staff. The following suggestions are listed for your assistance. You can make simple adjustments on your tractor that will improve its operation and save you the time and expense of hiring someone to do it for you. Always make one adjustment at a time, and if the adjustment made does not improve the condition, return to the original setting before proceeding to the next adjustment. Hard Starting Cold air temperatures. Insufficient fuel. ... [Read Article]
Latest Ad: Sell 1958 Hi-Altitude Massey Fergerson tractor, original condition. three point hitch pto engine, Runs well, photos available upon request [More Ads]
