Re: 466 flywheel in 560
Posted by K.B.-826 on September 06, 2007 at 19:28:39 from (68.115.95.144):
In Reply to: 466 flywheel in 560 posted by redsm on September 06, 2007 at 18:09:37:
You'd probably need a 966 or 986 flywheel. It should bolt up to your crank, and those two used the same clutch as 560.
Today's Featured Article - Diagnosing Engine Difficulty - Diesel Tractors - by Staff. The following suggestions are listed for your assistance. You can make simple adjustments on your tractor that will improve its operation and save you the time and expense of hiring someone to do it for you. Always make one adjustment at a time, and if the adjustment made does not improve the condition, return to the original setting before proceeding to the next adjustment. Hard Starting Cold air temperatures. Insufficient fuel. ... [Read Article]
Latest Ad: Sell 1958 Hi-Altitude Massey Fergerson tractor, original condition. three point hitch pto engine, Runs well, photos available upon request [More Ads]
