Probably the front seal. We have had alot of seals leak on the 400 series engines. The seal can be changed without removing the complete front end. Have to remnove fan and shroud. Remove A.C. compressor if equiped. If early tractor the front damper uses three hole puller late ones two hole. I use a hook type seal puller to remove seal. Put in new seal and wear ring on damper pulley. You will have to use two different lenghts of bolt to pull the damper back on the crankshaft using the retaining washer. Just make sure the crankshaft key is all the way in the groove and the pulley is lined up. Have any problems contact me
Today's Featured Article - Diagnosing Engine Difficulty - Diesel Tractors - by Staff. The following suggestions are listed for your assistance. You can make simple adjustments on your tractor that will improve its operation and save you the time and expense of hiring someone to do it for you. Always make one adjustment at a time, and if the adjustment made does not improve the condition, return to the original setting before proceeding to the next adjustment. Hard Starting Cold air temperatures. Insufficient fuel.
... [Read Article]
Latest Ad:
[More Ads]
