Re: 560 D - Developed a Miss
Posted by Robert Searcy on September 08, 2007 at 09:58:33 from (68.25.231.91):
In Reply to: 560 D - Developed a Miss posted by Robert Searcy on September 08, 2007 at 06:06:14:
No Unusual Noises, just hisses like a bad valve on a gas engine and low on power. Didnt go all at once, got worse over a couple days.
We can pull the injectors I presume and run a compression test.
What kind of compression should one of those things have??
No fluids where they shouldnt be and yes is smokes a little more than usual, more black and sooty when you pull, not white like getting water.
Today's Featured Article - Diagnosing Engine Difficulty - Diesel Tractors - by Staff. The following suggestions are listed for your assistance. You can make simple adjustments on your tractor that will improve its operation and save you the time and expense of hiring someone to do it for you. Always make one adjustment at a time, and if the adjustment made does not improve the condition, return to the original setting before proceeding to the next adjustment. Hard Starting Cold air temperatures. Insufficient fuel. ... [Read Article]
Latest Ad: Sell 1958 Hi-Altitude Massey Fergerson tractor, original condition. three point hitch pto engine, Runs well, photos available upon request [More Ads]
