If the #2 exhaust valve is not opening, the compression will be fine, but it will cause just that symptom. The valve may have stuck open for a second when first started and the pushrod fell off. With a tiny LED light you might be able to see the valve open in the spark plug hole. If not pull the valve cover to check. JimN
Today's Featured Article - Diagnosing Engine Difficulty - Diesel Tractors - by Staff. The following suggestions are listed for your assistance. You can make simple adjustments on your tractor that will improve its operation and save you the time and expense of hiring someone to do it for you. Always make one adjustment at a time, and if the adjustment made does not improve the condition, return to the original setting before proceeding to the next adjustment. Hard Starting Cold air temperatures. Insufficient fuel.
... [Read Article]
Latest Ad:
[More Ads]
