Posted by skk-big red fan on September 17, 2007 at 12:52:36 from (71.31.223.21):
In Reply to: Electrical Grounding posted by John T on September 17, 2007 at 08:17:17:
Which explains why a hot tub is required by code to have a full four wire circuit, two hot legs, a neutral and a additional separate grounding line, plus a ground rod installed at the tub & bonded to the neutral-frame-motor and grounding path, all tied to a dedicated GFI breaker? Or not.
Today's Featured Article - Diagnosing Engine Difficulty - Diesel Tractors - by Staff. The following suggestions are listed for your assistance. You can make simple adjustments on your tractor that will improve its operation and save you the time and expense of hiring someone to do it for you. Always make one adjustment at a time, and if the adjustment made does not improve the condition, return to the original setting before proceeding to the next adjustment. Hard Starting Cold air temperatures. Insufficient fuel.
... [Read Article]
Latest Ad:
[More Ads]
