Posted by John T on September 18, 2007 at 07:13:40 from (66.244.83.147):
In Reply to: measuring voltage posted by Farm130 on September 17, 2007 at 21:15:08:
Farm, Any open unloaded output voltage reading taken direct from a genny dont really tell you all that much which is why I agree 100% with Bob n Hugh below. Its the voltage the genny can supply when coupled up to a load that counts. If a charging system is working properly, battery voltage should rise from 6.3 to 6.5 to around 7 on a 6 volt battery and twice that on a 12 volt. Once the gennys output voltage rises higher then the batterys, the cutout relay should close in whch case (notwithstandign voltage drops) the battery voltage n the gennys would be near the same.
Today's Featured Article - Diagnosing Engine Difficulty - Diesel Tractors - by Staff. The following suggestions are listed for your assistance. You can make simple adjustments on your tractor that will improve its operation and save you the time and expense of hiring someone to do it for you. Always make one adjustment at a time, and if the adjustment made does not improve the condition, return to the original setting before proceeding to the next adjustment. Hard Starting Cold air temperatures. Insufficient fuel.
... [Read Article]
Latest Ad:
[More Ads]
