Posted by Uncle Fester on September 19, 2007 at 16:36:23 from (4.252.157.224):
Ok, I got the good stuff from Loctite and secured my two loose sleeves. Now one of the two that fit right does not have the right protrusion. It varies as you go around the circle, from +.002 to flush to -.0015. It is either flush or better for about 60 - 70 % of the circle. Problem or not?? If a problem can I simply drive it back up far enough to insert a few pieces of .002" shim stock under the rim??
Today's Featured Article - Diagnosing Engine Difficulty - Diesel Tractors - by Staff. The following suggestions are listed for your assistance. You can make simple adjustments on your tractor that will improve its operation and save you the time and expense of hiring someone to do it for you. Always make one adjustment at a time, and if the adjustment made does not improve the condition, return to the original setting before proceeding to the next adjustment. Hard Starting Cold air temperatures. Insufficient fuel.
... [Read Article]
Latest Ad:
[More Ads]
