Re: SMTA problems
Posted by RR Mech on September 19, 2007 at 20:19:53 from (12.154.7.21):
In Reply to: SMTA problems posted by Jim Bartnick on September 19, 2007 at 11:52:01:
Many times a idle problem is a leaking manifold gasket. It usually wont cause a problem when speeded up or when pulling a load. Hope this helps.
Today's Featured Article - Diagnosing Engine Difficulty - Diesel Tractors - by Staff. The following suggestions are listed for your assistance. You can make simple adjustments on your tractor that will improve its operation and save you the time and expense of hiring someone to do it for you. Always make one adjustment at a time, and if the adjustment made does not improve the condition, return to the original setting before proceeding to the next adjustment. Hard Starting Cold air temperatures. Insufficient fuel. ... [Read Article]
Latest Ad: Sell 1958 Hi-Altitude Massey Fergerson tractor, original condition. three point hitch pto engine, Runs well, photos available upon request [More Ads]
