Posted by Ted in NE on September 26, 2007 at 06:41:57 from (74.85.105.98):
In Reply to: IH Hydro question posted by Dave from MN on September 26, 2007 at 05:33:44:
Be sure and check the bolts that hold the fiberglass cover for the S/R lever. The holes will crack out and let the cover move. This changes the position of the lever. When you move the lever over to the side to go to forward or reverse you also seat a ball in the drive control valve. If the cover has shifted the ball can't seat properly, will loose drive pressure & tractor will stop. When the tractor stops idle down and push in on the lever see if it takes off again. If so adjust the cover as needed. This is a very common problem in an older tractor.Hope this helps
Today's Featured Article - Diagnosing Engine Difficulty - Diesel Tractors - by Staff. The following suggestions are listed for your assistance. You can make simple adjustments on your tractor that will improve its operation and save you the time and expense of hiring someone to do it for you. Always make one adjustment at a time, and if the adjustment made does not improve the condition, return to the original setting before proceeding to the next adjustment. Hard Starting Cold air temperatures. Insufficient fuel.
... [Read Article]
Latest Ad:
[More Ads]
