Hi Keith, I believe the large plug that you pulled was where an aux remote outlet would be installed and there will be no flow there unless the isolating valve is closed. Isolating valve is controlled by the knob at your right hand on the hydraulic valve body below the front of the seat. When the isolating valve is closed the flow is diverted from the 3pt to the aux remote port and is still controlled by the 3pt lever but the 3pt hitch will not work. The left hand knob controls the flow rate to the 3pt, selects either 2.5 or 5 gpm to the 3pt.
I have a B414 Operator Manual that has a simple diagram of hydraulic flow.
If you email me at clarabrownlee@rogers.com, I can scan a couple pages for you.
Today's Featured Article - Diagnosing Engine Difficulty - Diesel Tractors - by Staff. The following suggestions are listed for your assistance. You can make simple adjustments on your tractor that will improve its operation and save you the time and expense of hiring someone to do it for you. Always make one adjustment at a time, and if the adjustment made does not improve the condition, return to the original setting before proceeding to the next adjustment. Hard Starting Cold air temperatures. Insufficient fuel.
... [Read Article]
Latest Ad:
[More Ads]
