Posted by ScottyHOMEy on September 30, 2007 at 19:16:34 from (71.241.214.74):
In Reply to: Re: mc cormick c posted by Damp;Dservice on September 30, 2007 at 18:43:48:
If there's no water pump, it couldn't hurt to pull the elbow on top and make sure nobody tried to put a thermostat in there that might be stickkng on you.
Also lube your mag through the forward oil cap. If the impulse coupler in the mag is sticking, it could screw up your spark timing and make her run hot. Drop some light oil (like 3-in-1) in there and let it sit and dump some more in after you next start it up. Worst case (not all THAT bad) would be the owner's manual procedure for pulling the mag, flushing the impulse coupler with kerosene and resetting and retiming the mag, if that turns out to be the problem.
If that coupler has just got dirty or dry and stuck, it might very well be your problem
Today's Featured Article - Diagnosing Engine Difficulty - Diesel Tractors - by Staff. The following suggestions are listed for your assistance. You can make simple adjustments on your tractor that will improve its operation and save you the time and expense of hiring someone to do it for you. Always make one adjustment at a time, and if the adjustment made does not improve the condition, return to the original setting before proceeding to the next adjustment. Hard Starting Cold air temperatures. Insufficient fuel.
... [Read Article]
Latest Ad:
[More Ads]
