Posted by Janicholson on October 01, 2007 at 06:58:13 from (199.17.6.122):
In Reply to: Home-made ROPS posted by Daniel Bear Kelley on September 30, 2007 at 10:19:16:
ROPS when made by the owner may be as much a liability as it is a safert device. The use of seatbelts is mandatory. Getting pinched between the bars and the ground is worse than being able to jump off. The design will not have been tested to assure shear loads and crush loads are above those expected. Liability may be an issue if others are hurt/killed operating your machine with a non stock ROPS. With seat belts being used I think the idea is sound if looked at and built like one of the stock units, and fastened in the same robust manor. JimN
Today's Featured Article - Diagnosing Engine Difficulty - Diesel Tractors - by Staff. The following suggestions are listed for your assistance. You can make simple adjustments on your tractor that will improve its operation and save you the time and expense of hiring someone to do it for you. Always make one adjustment at a time, and if the adjustment made does not improve the condition, return to the original setting before proceeding to the next adjustment. Hard Starting Cold air temperatures. Insufficient fuel.
... [Read Article]
Latest Ad:
[More Ads]
