Posted by Janicholson on October 01, 2007 at 20:19:41 from (66.173.50.5):
In Reply to: Valve Adjustment posted by Brian Jensen on October 01, 2007 at 15:34:26:
I do not have the specification cold, but here is the method (works on all four stroke engines, kinda handy. Locate the intake and exhaust valves from front it is E-I I-E E-I I-E on four cylinder Farmalls. Turning the engine by hand with plugs out and in gas mode ign off. Treat each cylinder alone. Turn engine in the correct direction, until #1 intake just closes (comes up)and just stops. Adjust the exhaust valve. Turn the engine until the #1 exhaust valve just starts to move (downward). Adjust the intake. This puts the cam at a known position to allow the other valve to be adjusted. Do the same for each cylinder until done. Be sure to keep to one cylinder at a time, and the which valve is which. Put a magic marker tick on each intake and be careful. JimN
Today's Featured Article - Diagnosing Engine Difficulty - Diesel Tractors - by Staff. The following suggestions are listed for your assistance. You can make simple adjustments on your tractor that will improve its operation and save you the time and expense of hiring someone to do it for you. Always make one adjustment at a time, and if the adjustment made does not improve the condition, return to the original setting before proceeding to the next adjustment. Hard Starting Cold air temperatures. Insufficient fuel.
... [Read Article]
Latest Ad:
[More Ads]
