Posted by Pete in Holland, MI on October 03, 2007 at 13:42:24 from (198.36.89.7):
In Reply to: starting problem posted by Bill Pingel on October 02, 2007 at 19:27:43:
Did you replace all 3 cables? Clean he connections to the engine? Have seen some cables clamped to a battery box or piece of tin. The junction here may be o.k., but where the tin joins the engine may be the problem. Suggest your ground strap go right to a bolt that screws into the engine block or transmission housing. Might take a wire directly from the battery to the motor starter to see if the starter switch itself is at fault.
Was told several years back that the electrical system on a tractor should be completely replaced every 15-20 years. That'll prevent a lot of little problems in the up and coming years.
Today's Featured Article - Diagnosing Engine Difficulty - Diesel Tractors - by Staff. The following suggestions are listed for your assistance. You can make simple adjustments on your tractor that will improve its operation and save you the time and expense of hiring someone to do it for you. Always make one adjustment at a time, and if the adjustment made does not improve the condition, return to the original setting before proceeding to the next adjustment. Hard Starting Cold air temperatures. Insufficient fuel.
... [Read Article]
Latest Ad:
[More Ads]
