Posted by Andy Motteberg on October 05, 2007 at 12:36:10 from (4.143.221.100):
Hi, I re-wired my 1943 Farmall H exactly how Bob M's wiring diagram showed. Everything seems to be working good. One night I was putting the front wheels back on the tractor and I needed more light, so I turned on the DIM headlights when the tractor was not running. While I was working, I could smell something burning, so I looked at the Dash (switch box) and there was smoke coming from it, I quickly pulled off the Positive battery cable (ground). It was too dark to see inside the switch box, but I felt all the wires on the tractor and they were not hot or anything. The next day, I took apart the switch box to check the fuse. It is the correct amps and was not blown. Nothing I could see had any signs of being "burned" or damaged, everything looked normal. This is strange, what is causing this??? I have not turned on the lights since then.
Today's Featured Article - Diagnosing Engine Difficulty - Diesel Tractors - by Staff. The following suggestions are listed for your assistance. You can make simple adjustments on your tractor that will improve its operation and save you the time and expense of hiring someone to do it for you. Always make one adjustment at a time, and if the adjustment made does not improve the condition, return to the original setting before proceeding to the next adjustment. Hard Starting Cold air temperatures. Insufficient fuel.
... [Read Article]
Latest Ad:
[More Ads]
