tach dwell meter from an auto store will do very well at the task. It has two leads one to ground, and one to the terminal on the side of the distributor. Easy and foolproof. Also works on any voltage system with a coil/points. Shaft driven tachs that can be touched to the end of the PTO also work well. Finally a strobe tach is the handiest. It uses a flashing light and a knob to adjust the speed of the flash. As the flash synchronizes with the engine speed, the front pulley stops (apparently, not really)and the readout is RPM on a LCD, or needle scale. JimN
Today's Featured Article - Diagnosing Engine Difficulty - Diesel Tractors - by Staff. The following suggestions are listed for your assistance. You can make simple adjustments on your tractor that will improve its operation and save you the time and expense of hiring someone to do it for you. Always make one adjustment at a time, and if the adjustment made does not improve the condition, return to the original setting before proceeding to the next adjustment. Hard Starting Cold air temperatures. Insufficient fuel.
... [Read Article]
Latest Ad:
[More Ads]
