Posted by russ hamm on October 15, 2007 at 09:45:05 from (63.245.179.200):
In Reply to: 1-PR corn picker posted by riverbend on October 14, 2007 at 18:44:00:
I have one of those pickers also. My main advice is this; a tractor with a t/a or creeper gear in good corn!!!! We found our 350 utility in low with the t/a back worked well, even in double run corn. BUT, the farmall 300 the same way was too fast. Had to clutch now and then. If we went too fast, we had stalk problems and the ears would shell. If we went as slow as possible, no problems. If you can't get slow enough, put one tractor on for pto only, and pull it with another one for ground speed. Then you can run the front tractor at less rpm and keep the rear tractor up to the needed pto rpm.
Today's Featured Article - Harvestin Hay: The Early Years (Part 2) - by Pat Browning. The summer of 1950 was the start of a new era in farming for our family. I was thirteen, and Kathy (my oldest sister) was seven. At this age, I believed tractor farming was the only way, hot stuff -- and given a chance I probably would have used the tractor, Dad's first, a 1936 Model "A" John Deere, to go bring in the cows! And I think Dad was ready for some automation too. And so it was that we acquired a good, used J. I. Case, wire tie hay baler. In addition to a person to drive th
... [Read Article]
Latest Ad:
[More Ads]
