Use an analog meter.
Posted by Bob on October 20, 2007 at 13:49:39 from (69.178.229.154):
In Reply to: voltage at alternator reading posted by keith smith on October 20, 2007 at 13:42:33:
The noisy electrical systems on these old machines often give digital meters a sick headache.
Even a cheap analog meter is more than accurate enough for this use, and won't be affected by the EMI.
You want to see about 14.5 Volts on the large output stud, and the #1 and #2 terminals with the engine running.
With the engine STOPPED, the voltage on the #1 ("switched excite") terminal should drop to zero.
If it doesn't drop to zero, the alternator will remain "excited" and drain the battery.
Today's Featured Article - Diagnosing Engine Difficulty - Diesel Tractors - by Staff. The following suggestions are listed for your assistance. You can make simple adjustments on your tractor that will improve its operation and save you the time and expense of hiring someone to do it for you. Always make one adjustment at a time, and if the adjustment made does not improve the condition, return to the original setting before proceeding to the next adjustment. Hard Starting Cold air temperatures. Insufficient fuel. ... [Read Article]
Latest Ad: Sell 1958 Hi-Altitude Massey Fergerson tractor, original condition. three point hitch pto engine, Runs well, photos available upon request [More Ads]
