Hi Stewart,I set the valves at .012-.014 cold, the owner's manual says .009 hot. I have never seen a published value for the rods or headbolts, as for the rods the clearance is more important than the torque value, I try to get the shims right and then tighten the caps down good, then check to make sure the rod bearing is not tight on the journal. For the headbolts I go 100lbs. with clean, oiled threads, but I am always nervous as the only headbolt I ever broke was on the first F20 I had.
Today's Featured Article - Diagnosing Engine Difficulty - Diesel Tractors - by Staff. The following suggestions are listed for your assistance. You can make simple adjustments on your tractor that will improve its operation and save you the time and expense of hiring someone to do it for you. Always make one adjustment at a time, and if the adjustment made does not improve the condition, return to the original setting before proceeding to the next adjustment. Hard Starting Cold air temperatures. Insufficient fuel.
... [Read Article]
Latest Ad:
[More Ads]
