Posted by Brownie450 on November 06, 2007 at 15:51:31 from (207.177.82.74):
In Reply to: 826 front spindles. posted by Bradford on November 05, 2007 at 17:24:15:
If your 826 is similar to the 1066, & I think it is, try fitting a thin rim machinery washer[bushing] up in where the thrust bearing fits & see if it fills the worn area which was damaged. This made a lot of difference on the 1066. In fact, the splined steering arm could be cranked down tight enough to take up all play. Good luck with yours.
Today's Featured Article - Diagnosing Engine Difficulty - Diesel Tractors - by Staff. The following suggestions are listed for your assistance. You can make simple adjustments on your tractor that will improve its operation and save you the time and expense of hiring someone to do it for you. Always make one adjustment at a time, and if the adjustment made does not improve the condition, return to the original setting before proceeding to the next adjustment. Hard Starting Cold air temperatures. Insufficient fuel.
... [Read Article]
Latest Ad:
[More Ads]
