Re: Want To Put Duels On a Farmall H.
Posted by WOEII on November 21, 2007 at 15:01:59 from (70.127.118.235):
In Reply to: Want To Put Duels On a Farmall H. posted by 300Randy on November 21, 2007 at 13:04:32:
Ole Sow 53 said: (quoted from post at 14:59:12 11/21/07) I just measured my H it has 11.2 x 38 and 10" rims
it look like you would have 1" to 1.5" between the duals of the same size with both wheels cupped out. Bigger tires or wider rims would not work.
Some Hs came with 100" axles instead of 80". Try finding some of them.
Any idea on how much over the the center would be past the axel?
The 100' axles would do the trick I am sure. Tracking something like that down is gonna be a nightmare but it's a good sign that there are options. third party image
Today's Featured Article - Diagnosing Engine Difficulty - Diesel Tractors - by Staff. The following suggestions are listed for your assistance. You can make simple adjustments on your tractor that will improve its operation and save you the time and expense of hiring someone to do it for you. Always make one adjustment at a time, and if the adjustment made does not improve the condition, return to the original setting before proceeding to the next adjustment. Hard Starting Cold air temperatures. Insufficient fuel. ... [Read Article]
Latest Ad: Sell 1958 Hi-Altitude Massey Fergerson tractor, original condition. three point hitch pto engine, Runs well, photos available upon request [More Ads]
