Posted by SDE on December 01, 2007 at 07:43:59 from (69.179.31.26):
In Reply to: My rebuilt M posted by Carden on December 01, 2007 at 05:30:44:
If you are going into the woods with this tractor to pull out trees and clear stumps, you may not want to rush into getting new rear tires. Buy some tire chains for using during the snow season. Most chains will work better with worn tires instead of new ones. How much weight do you have installed on the wheels? I put a second set of weights on mine this fall and I put on near new 13.6s, which replaced worn 14.9. I also have chains if I need them. If I were going to use it in the woods I would most likely put the old tires back on it. SDE
Today's Featured Article - Diagnosing Engine Difficulty - Diesel Tractors - by Staff. The following suggestions are listed for your assistance. You can make simple adjustments on your tractor that will improve its operation and save you the time and expense of hiring someone to do it for you. Always make one adjustment at a time, and if the adjustment made does not improve the condition, return to the original setting before proceeding to the next adjustment. Hard Starting Cold air temperatures. Insufficient fuel.
... [Read Article]
Latest Ad:
[More Ads]
