Re: 560 D PTO
Posted by Ronald on December 02, 2007 at 06:36:31 from (64.12.116.73):
In Reply to: 560 D PTO posted by Tom/Idaho on December 01, 2007 at 17:39:49:
Tom, I had a similar problem with my 560. I was roudbaling and when the bale got about full the pto would slip. If your clutch"s are in good shape put the unit in the vise per the service manual( I have one if you need a copy of those pages). and tighten the main nut. You should have to put a piece of pipe on the arm to make it break over center. The newer pto units you could adjust on the tractor if that"s what you have.
Today's Featured Article - Diagnosing Engine Difficulty - Diesel Tractors - by Staff. The following suggestions are listed for your assistance. You can make simple adjustments on your tractor that will improve its operation and save you the time and expense of hiring someone to do it for you. Always make one adjustment at a time, and if the adjustment made does not improve the condition, return to the original setting before proceeding to the next adjustment. Hard Starting Cold air temperatures. Insufficient fuel. ... [Read Article]
Latest Ad: Sell 1958 Hi-Altitude Massey Fergerson tractor, original condition. three point hitch pto engine, Runs well, photos available upon request [More Ads]
