Posted by Janicholson on December 02, 2007 at 13:54:26 from (66.173.50.145):
Dear Carl, I believe you should replace the cam gear in the original tractor. If you begin with the idea of taking the front bolster radiator, and front cover off, and find the gear broken, all takes is new, or used higher strength gears (pretty easy fix) Then you will have a tractor to sell and be in business again. If the original M has good gears, and something else is wrong, then you are 1/2 of the way to putting the correct front cover on the new M. Best of luck, and keep us informed. JimN
Today's Featured Article - Diagnosing Engine Difficulty - Diesel Tractors - by Staff. The following suggestions are listed for your assistance. You can make simple adjustments on your tractor that will improve its operation and save you the time and expense of hiring someone to do it for you. Always make one adjustment at a time, and if the adjustment made does not improve the condition, return to the original setting before proceeding to the next adjustment. Hard Starting Cold air temperatures. Insufficient fuel.
... [Read Article]
Latest Ad:
[More Ads]
