With out putting the gauges to it and seeing what ya have for pressures And like Chuck said does your brakes work and is the T/A shifting if ya have one it could be a pice of dirt or something in the steering orface A blowen MCV gskt or O/ring . Week springs something binding in the steering . Before ya just start tearing into this one MUST have a book a clean place to work something to drain 18 gallon of Hy Tran into . Have you changed the Hy Tran and filter lately . If ya are not up on hyd. repair then it may be best to have someone that knowes what they are doing work on it as you sure do not want to try and jack pressure up much over factory spec.'s or one could find his MCV flyen off the tractor and ya would not be the first that blew one off the tractor then little 5/16ths bolts will only take so much.
Today's Featured Article - Diagnosing Engine Difficulty - Diesel Tractors - by Staff. The following suggestions are listed for your assistance. You can make simple adjustments on your tractor that will improve its operation and save you the time and expense of hiring someone to do it for you. Always make one adjustment at a time, and if the adjustment made does not improve the condition, return to the original setting before proceeding to the next adjustment. Hard Starting Cold air temperatures. Insufficient fuel.
... [Read Article]
Latest Ad:
[More Ads]
