Posted by Frank DeWitt on December 24, 2007 at 11:21:23 from (65.37.10.103):
was using the Farmall 200 on Sunday and I put it away. shut off the fuel, and was waiting for it to run out of gas when a LOUD Bang. I look over at the gauges and the glass is gone from the Amp meter and what is left doesn't look to good. I pull the battery, and sure enough The area between the battery and the switches and gauges is packed full of mice nest and dead mice. I hate mice.
Cleaned everything out last night including the dead meter and the dead temp gauge (mice stuff rotted though the tubing. (I hate mice) Today I put in new gauges and new wiring in that area. Every thing works now.
Some observations and questions.
Farmall didn't fuse much. Only the lights are fused. also, the glass fuse and fuse holder don't work real well. I found that NAPA sells some nice after market fuse holders. http://www.bussmann.com/images/8ef32c7b-c26c-4fd0-b016-471b7f380230.jpg http://www.bussmann.com/images/44fcdd4b-b905-4688-9176-cc90024f7930.jpg I installed one of these for the lights and left it poking out near the back corner of the battery side plates It doesn't show unless you know it is there. I think this spring I may add one at the 6V output at the start switch. Perhaps another at the output of the generator.
From past experience plus observing what is in there. Crimp on connectors will corrode. Crimp and solder Those wire nuts that are pre filled with weather proof goop for trucking use DO work. The wires were nice and clean.
Mice like to eat the new plastic wire more then the old plastic or cloth covered wire. Does any one know why? or where to get the old kind of wire? The hardware store thought heat resistant wire might work. He only had #14.
BIG Question. How do I keep mice out of my tractor. What do you do? Do I need to inspect it once or twice a year? How about that Mice be gone spray? Moth balls? I protect my antique generator with mothballs, but I seal it in plastic to do it.
Today's Featured Article - Diagnosing Engine Difficulty - Diesel Tractors - by Staff. The following suggestions are listed for your assistance. You can make simple adjustments on your tractor that will improve its operation and save you the time and expense of hiring someone to do it for you. Always make one adjustment at a time, and if the adjustment made does not improve the condition, return to the original setting before proceeding to the next adjustment. Hard Starting Cold air temperatures. Insufficient fuel.
... [Read Article]
Latest Ad:
[More Ads]
