I just overhauled engine.Stepped pistons,gas head,and had berry cam regrind camshaft.I had a real hard time getting it started.I had the pipe off the carb and after cranking gas would pour out the end of the carb.Giving it some thought I attached the pipe sprayed a shot of ether in the air cleaner and it started after a couple of cranks.Ran rough at first but smoothed out sounds real nice for a change.
Also is there some changes that should be made to the governor after doing the above to engine.
Today's Featured Article - Diagnosing Engine Difficulty - Diesel Tractors - by Staff. The following suggestions are listed for your assistance. You can make simple adjustments on your tractor that will improve its operation and save you the time and expense of hiring someone to do it for you. Always make one adjustment at a time, and if the adjustment made does not improve the condition, return to the original setting before proceeding to the next adjustment. Hard Starting Cold air temperatures. Insufficient fuel.
... [Read Article]
Latest Ad:
[More Ads]
