Re: How to remove front crank pulley on a 48 cub?
Posted by Gauger on January 19, 2008 at 05:52:33 from (4.252.156.132):
In Reply to: How to remove front crank pulley on a 48 cub? posted by skeedad on January 18, 2008 at 15:04:51:
That hydraulic puller is very nice. I have removed a bunch with a LARGE two jaw puller and the bearing separator (backing plate). The backing plate is the key. In my Farmall "formative years" I broke the first pulley I tried to remove with just a puller and not the backing plate. Expensive lesson. Heat can also be required.
Today's Featured Article - Diagnosing Engine Difficulty - Diesel Tractors - by Staff. The following suggestions are listed for your assistance. You can make simple adjustments on your tractor that will improve its operation and save you the time and expense of hiring someone to do it for you. Always make one adjustment at a time, and if the adjustment made does not improve the condition, return to the original setting before proceeding to the next adjustment. Hard Starting Cold air temperatures. Insufficient fuel. ... [Read Article]
Latest Ad: Sell 1958 Hi-Altitude Massey Fergerson tractor, original condition. three point hitch pto engine, Runs well, photos available upon request [More Ads]
