With the engine warmed up try this: remove all spark plugs and re-do the compression test only squirt some clean engine oil in each cylinder first, crank the engine to spread the oil around, and repeat the compression test. You did have the throttle wide open to allow maximum air entry, didn't you? If all readings increase 10-2- pounds, this indicates worn rings. With all readings even, the valves are not suspect. To get a more accurate result, purchase a leak-down tester. It will tell you exactly how much leakage your engine has and where it is leaking.
Today's Featured Article - Diagnosing Engine Difficulty - Diesel Tractors - by Staff. The following suggestions are listed for your assistance. You can make simple adjustments on your tractor that will improve its operation and save you the time and expense of hiring someone to do it for you. Always make one adjustment at a time, and if the adjustment made does not improve the condition, return to the original setting before proceeding to the next adjustment. Hard Starting Cold air temperatures. Insufficient fuel.
... [Read Article]
Latest Ad:
[More Ads]
