Two possible answers. Unless the rearend is without lube it is uncommon for them to grind internally only while braking. The bands may look OK from the point of view of the edge, but be worn enough to allow the rivets to wear into the outside of the drum. The brake bands might also be glazed and making vibrating grinding noise from stickstion (stick slip stick slip stick slip) this can sound low and like a groan, or higher in pitch. If that is it, sanding the glaze off the band and drum with 320 grit, will cure it for a few days (or less)but then you know what it is and can continue to ignore it. JimN
Today's Featured Article - Diagnosing Engine Difficulty - Diesel Tractors - by Staff. The following suggestions are listed for your assistance. You can make simple adjustments on your tractor that will improve its operation and save you the time and expense of hiring someone to do it for you. Always make one adjustment at a time, and if the adjustment made does not improve the condition, return to the original setting before proceeding to the next adjustment. Hard Starting Cold air temperatures. Insufficient fuel.
... [Read Article]
Latest Ad:
[More Ads]
