Posted by Oldoaky-2 on February 07, 2008 at 09:49:54 from (66.172.252.63):
In Reply to: massey harris pony posted by steveindy on February 07, 2008 at 07:36:22:
I dont know much about MF, but it could have shims in the rod and main bearings, or they probably did not check the clearance on the main and rod bearings. Loosen up the rod bearings and try turning it over,if not loosen the main bearings, then it should be loose. Just might have to put in different bearings if they are to tight. I agree with the other posts. Interesting. Let us know what happens.
Today's Featured Article - Diagnosing Engine Difficulty - Diesel Tractors - by Staff. The following suggestions are listed for your assistance. You can make simple adjustments on your tractor that will improve its operation and save you the time and expense of hiring someone to do it for you. Always make one adjustment at a time, and if the adjustment made does not improve the condition, return to the original setting before proceeding to the next adjustment. Hard Starting Cold air temperatures. Insufficient fuel.
... [Read Article]
Latest Ad:
[More Ads]
