Posted by Larry Condon on February 08, 2008 at 07:12:57 from (64.254.184.241):
In Reply to: Farmall C clutch posted by Kristof on February 08, 2008 at 00:32:47:
You must be referring to the throw out fingers. I had the same problem with a F20 clutch. Be careful with just trying to drill out the holes larger. If worn oblong the drill will wander out of concentricity and you will have a hole that is not round and out of location. I fixed mine by setting up in my milling machine and bored the holes to clean up. I then made bushings and pressed them in. The holes in the finger brackets were worn and the fingers where not. The pins where worn some. Made the pins new and left the fingers as was.
Today's Featured Article - Diagnosing Engine Difficulty - Diesel Tractors - by Staff. The following suggestions are listed for your assistance. You can make simple adjustments on your tractor that will improve its operation and save you the time and expense of hiring someone to do it for you. Always make one adjustment at a time, and if the adjustment made does not improve the condition, return to the original setting before proceeding to the next adjustment. Hard Starting Cold air temperatures. Insufficient fuel.
... [Read Article]
Latest Ad:
[More Ads]
