424 Hydraulics - Closed or Open Center
Posted by Mike Siless on February 20, 2008 at 11:13:14 from (207.241.244.90):
I have a log splitter set up for the open center system on my '71 JD 820. I'd like to be able to also use the splitter on my '67 IH 424. The 424 has a single hose loader (trip bucket) that operates off of the lever below the seat. I haven't figured out the remotes on the back of the tractor yet. I figured that since the 424 has the separate oil reservoir for the hydraulics, by using the same fluid in both tractors I'd avoid contamination. My question, is the 424 an open center system like the JD, how should I plumb it for the 424, and does anyone foresee a problem sharing the splitter? Thanks in advance.
Today's Featured Article - Diagnosing Engine Difficulty - Diesel Tractors - by Staff. The following suggestions are listed for your assistance. You can make simple adjustments on your tractor that will improve its operation and save you the time and expense of hiring someone to do it for you. Always make one adjustment at a time, and if the adjustment made does not improve the condition, return to the original setting before proceeding to the next adjustment. Hard Starting Cold air temperatures. Insufficient fuel. ... [Read Article]
Latest Ad: Sell 1958 Hi-Altitude Massey Fergerson tractor, original condition. three point hitch pto engine, Runs well, photos available upon request [More Ads]
