Posted by Janicholson on February 25, 2008 at 13:40:57 from (199.17.6.122):
In Reply to: H high idle speed posted by Alan Martinson on February 25, 2008 at 13:05:02:
I believe one of two issues may be involved.
Either the throttle plate is not centered in the bore and hanging up on something, or the governor tang and slot connecting the carb to shaft is actually not in the groove. Loosen the screws holding the throttle plate just a little and center the plate in its bore at Idle. (Idle sped screw turned out to allow it to touch the bore.
The tang and slot can be seen by removing the two bolts holding it to the carb, and peek inside. JimN
Today's Featured Article - Diagnosing Engine Difficulty - Diesel Tractors - by Staff. The following suggestions are listed for your assistance. You can make simple adjustments on your tractor that will improve its operation and save you the time and expense of hiring someone to do it for you. Always make one adjustment at a time, and if the adjustment made does not improve the condition, return to the original setting before proceeding to the next adjustment. Hard Starting Cold air temperatures. Insufficient fuel.
... [Read Article]
Latest Ad:
[More Ads]
