Posted by No tools on February 25, 2008 at 18:58:02 from (71.79.47.23):
In Reply to: Trouble 450 clutch posted by james3504 on February 25, 2008 at 17:29:25:
NO 1 Did you align with tool or eye. No 2 you bolted P P and clutch disc tight to flywheel before attaching two halves of tractor together? No 3 if so you have warped the disc. No 4 remove the disc.install another new one. No 5 this time put PP on shaft install disc in front of it. No 6 attach two halves. No 7 you still have the (BATTERY) unhooked coil wire removed. No 8 go up through the bottom of clutch housing opening inspection hole install bolts in PP assembly.
Today's Featured Article - Diagnosing Engine Difficulty - Diesel Tractors - by Staff. The following suggestions are listed for your assistance. You can make simple adjustments on your tractor that will improve its operation and save you the time and expense of hiring someone to do it for you. Always make one adjustment at a time, and if the adjustment made does not improve the condition, return to the original setting before proceeding to the next adjustment. Hard Starting Cold air temperatures. Insufficient fuel.
... [Read Article]
Latest Ad:
[More Ads]
