706 Again
Posted by Zach from TX on March 05, 2008 at 15:13:49 from (75.104.102.107):
OK, third post on this tractor. Another question. What is wrong with the hydraulic system when the power steering won't work?
Filter is new
Brakes work
Front pump puts out pressure at the MCV orifice but no oil at the small sending unit above the MCV orifice.
Also, the 3 point is stuck in the up position, and remotes don't seem to pressure up.
Sure do appreciate the info and advice on the last two questions.
Today's Featured Article - Diagnosing Engine Difficulty - Diesel Tractors - by Staff. The following suggestions are listed for your assistance. You can make simple adjustments on your tractor that will improve its operation and save you the time and expense of hiring someone to do it for you. Always make one adjustment at a time, and if the adjustment made does not improve the condition, return to the original setting before proceeding to the next adjustment. Hard Starting Cold air temperatures. Insufficient fuel. ... [Read Article]
Latest Ad: Sell 1958 Hi-Altitude Massey Fergerson tractor, original condition. three point hitch pto engine, Runs well, photos available upon request [More Ads]
