Cheapest way to go on a W-series tractor would be a shaft straight through the front bolster to a pump. Took a Char-Lynn set up off a WD9 a few years back, should have taken pictures...
Pretty easy to make a mount with those 4 bolt holes right up there, simple sleeve over the crankshaft with a pin through it and a shaft/sleeve to the pump. Could probably set it all up for around $250, depending on how big of a pump you need.
Today's Featured Article - Diagnosing Engine Difficulty - Diesel Tractors - by Staff. The following suggestions are listed for your assistance. You can make simple adjustments on your tractor that will improve its operation and save you the time and expense of hiring someone to do it for you. Always make one adjustment at a time, and if the adjustment made does not improve the condition, return to the original setting before proceeding to the next adjustment. Hard Starting Cold air temperatures. Insufficient fuel.
... [Read Article]
Latest Ad:
[More Ads]
