If you combine is an early 303 it should have a BD220 engine. Later ones had the C221. If the governor looks the same as your tractor, then it is the later engine. The BD series engines are truck engines and though the look pretty much the same, they are not too interchangeable. The problem will be with the governor and front cover. The bolts on the front of the block are different sizes. The timing gears are different so I do not know if you could make the tractor governor work. If it is a C221, the crankshafts are different. The tractor will have a longer stroke. The C 221 would be an engine for a 460.
Today's Featured Article - Diagnosing Engine Difficulty - Diesel Tractors - by Staff. The following suggestions are listed for your assistance. You can make simple adjustments on your tractor that will improve its operation and save you the time and expense of hiring someone to do it for you. Always make one adjustment at a time, and if the adjustment made does not improve the condition, return to the original setting before proceeding to the next adjustment. Hard Starting Cold air temperatures. Insufficient fuel.
... [Read Article]
Latest Ad:
[More Ads]
